-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   '98 4WD S-10 Blazer Wheel Rotation Clunk When Turning (https://blazerforum.com/forum/general-tech-help-7/98-4wd-s-10-blazer-wheel-rotation-clunk-when-turning-6766/)
raviz 11-21-2006 02:58 AM
My '98 4WD with 45K miles has started to "clunk' once every tire revolution when making a right turn at any speed, including at a slow crawl. The sharper the turn, the louder the noise. I can also feel the clunk on the steering wheel or the shift selector.
The noise is nearly gone when going straight ahead and completely gone when making a left turn. This has been going on for about the last 3K miles, and is becoming worse at a very slow rate.
My initial guess is that it's an outside front CV joint because it doesn't get worse with increasing speed while turning like a typical bad wheel bearing will do. It only increases
when the turn sharpens.
What do the experts out there think??
Chevy Lover 11-21-2006 03:44 AM
RE: '98 4WD S-10 Blazer Wheel Rotation Clunk When Turning
By your description, I agree that it sounds like a left outer c/v. As you turn right , the vehicle weight shifts to the left.
swartlkk 11-21-2006 09:54 AM
Yeah, I'd have to say you've got a CV failure of one kind or another. Look for a torn CV boot cause that will often cause premature CV joint failure.
