'98 blazer side view mirror
Anyone ever replaced a powered, heated side view mirror? Any tips?
RE: '98 blazer side view mirror
Welcome to the forum.
Remove the door trim panel.. Remove the access hole plugs. Remove the nuts that retain the outside rearview mirror to the door. Remove the outside rearview mirror from the door. Disconnect the electrical connector, Installation Procedure Connect the electrical connector, Install the outside rearview mirror to the door. Install the nuts that retain the outside rearview mirror to the door. Tighten Tighten the nuts to 6 N·m (53 lb in). Install the access hole plugs. Install the door trim panel. . |
| All times are GMT -5. The time now is 02:24 PM. |
