-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   ABS light? (https://blazerforum.com/forum/general-tech-help-7/abs-light-2882/)
DaNK 305 Mar 19, 2006 01:59 PM
ABS light?
ya my ABS light just turned on out of no were.. but the brake works fine, does anyone have any suggestions or has this light turned on for anyone elsE?
thanks
Binz316 Mar 19, 2006 03:16 PM
RE: ABS light?
by friends 94 had that trouble and we replaced a speed sensor on one of the rear wheels and it went away.
SniperX13 Mar 19, 2006 06:01 PM
RE: ABS light?
what were the circumstances of the sensor going out? were you able to tell? My wife and I just got back from a trip in her '94 S-10 Blazer Tahoe LT, and after stopping to get gas at one of those highway stops, the ABS light came on, but the brakes worked fine, except for a tiny squeak from the brakes when stopping fully.
could this be the sensor too?
the light came onright when the vehicle started and didnt shut off the whole way home.
4lowlife Mar 19, 2006 07:20 PM
RE: ABS light?
Check the ohmatic value of both wheel bearing wires. I don't know their supposed values. It help to find if one has a wildly different value than the other.
Binz316 Mar 19, 2006 10:38 PM
RE: ABS light?
quite possibly sniper. I know reading my haynes book on the blazer there are error codes for the abs system. The one we pulled told us it was an error with a speed sensor, pulled it and replaced it..voila.
SniperX13 Mar 19, 2006 11:03 PM
RE: ABS light?
ORIGINAL: Binz316
Is it possible, that rain had a factor in the light coming on? I drove from Wichita back to Topeka, and it was rainy the entire way.
Binz316 Mar 19, 2006 11:38 PM
RE: ABS light?
perhaps, but if the light stays on have the code checked.
DaNK 305 Mar 20, 2006 09:45 AM
RE: ABS light?
ya i think it is a sensor that went bad...
thanks for the feedback
Hanr3 Mar 20, 2006 01:09 PM
RE: ABS light?
Went bad or got covered in dirt/grease?
Johnnyboy Mar 20, 2006 02:47 PM
RE: ABS light?
Just my 2 cents worth. Like all computer controlled stuff on the vehicle, you can check for any error codes stored in the BPMV (brake pressure modulator valve) located on the inside left side of the fender. This valve does a self diagnostic everytime you turn on your vehicle. Jump your DLC plug inside, on my 94 you jump "A" pin (top right-ground) & the "H" pin, bottom row second pin from the left. I'm sure its different on newer models. But the ABS light will flash my codes. Someone might have a better idea with your model. Or you might need a scan tool. Good luck
