air vents
Is it an easy job to try and clean leaves out of your heater and a/c fan, will it come out easy, I think I have some up in there, also on the top grill by the windshield. thanks
RE: air vents
It shouldn't be too difficult. On my 2k, I'd have to remove the windshield wipers to remove the cowl cover, and I think on the '94s (which have a steel cowl cover IIRC), you'd have to do the same thing. Just make sure that you mark at what angle the arms go on and I think they just get bolted on. Pop off the cap and remove the nut, then pry the arm off. Remove the screws/bolts that hold on the cowl cover, then suck out the leaves with a shop vac or pull them out with your hands.
Good luck |
