a/c works after about 10 minutes
My A/c takes about 10 minutes at the start of each day to come on. Once it comes on it works fine the rest of the day. I have jumped out the low pressure switch and it still does nothing. Then wait about 10mins and it comes on. Any ideas?? 97 blazer
Thanks |
RE: a/c works after about 10 minutes
ok a/c is not my specialty considering mine hasnt worked in over a year, but it usually takes a little while for the a/c to really start working in any car but 10 minutes does seem a little longer than normal.....when it does start working how cool is the air?(does it work great or just blow out kinda cool air)
it takes 10minutes for the compressor to come one, then it is very cool
do you ever here the clutch kick on all the time?
I you do it is low on coolant |
it's not low because I can jump out the low pressure switch and it still doesnt come on
Check your cooling fan clutch sounds like you may have a HIGH pressure issue.
