General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
coolant leak
Old Mar 1, 2006 | 12:52 PM
dashyman's Avatar
dashyman is an unknown quantity at this point
Default coolant leak
95 blazer 4.3
I am losing a lot of coolant and don't know where it is coming from. I understand that the 4.3 is noted for having a bad intake manifold that deterioates could this be the source?
Also every now and then the car starts to run rough and sort of
diesels - if I reset the computer it runs fine until the next time - any ideas?
Old Mar 1, 2006 | 02:44 PM
Hanr3's Avatar
Default RE: coolant leak
You need to find out where the coolant is going, it has to be going somewhere. Check your oil and tranny dipsticks. Do you smell it? Check the floor under your passengers feet, is it wet. Do you have a white cloud following you where ever you go?
Old Mar 1, 2006 | 02:53 PM
dashyman's Avatar
oil is clean, floor is wet
Old Mar 1, 2006 | 04:38 PM
Binz316's Avatar
Binz316 is an unknown quantity at this point
sounds like a heater core..
Old Mar 1, 2006 | 04:41 PM
dashyman's Avatar
nope, not the HC - floor is wet in front of motor and in rear
Old Mar 1, 2006 | 04:44 PM
Binz316's Avatar
wet outside the vehicle? maybe head gasket. also check around the water pump and follow all the hoses for leaks or cracks.
Old Jun 4, 2006 | 11:21 PM
jikastew's Avatar
jikastew is an unknown quantity at this point
I have a similar problem I just encourtered.
My leak is easily noted to be coming from where the engine to radiator outflow hose starts. I, unfortunately, know little about engines. It appears to be a seal in that area. When the truck starts, the coolant drips like a sieve out of that area.
Any ideas?
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
john
Oct 4, 2006 03:02 PM
edacsac
Feb 10, 2006 06:04 PM
