General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
decelleration noise in 98 blazer
Old May 24, 2006 | 12:49 PM
st_pinetree's Avatar
st_pinetree is an unknown quantity at this point
Default decelleration noise in 98 blazer
I have done several searches and found multiple people with the same syptoms I am having. However no clear fixes are listed in any of the posts. Occasionally when slowing from highway speed I get an awful howl/grind noise in what sounds like the front end. Similar to the sound you would get if you picked up a piece of trash on your driveline or something. It diminishes as you slow and turns into a series of clicking sounds. If I hit the 4wd button it goes away and all is fine. From what I've read on the internet, I am thinking its a problem with the axle acuator partially engaging the axle on its own. Do I replace the vacuum switch?
Old May 24, 2006 | 02:22 PM
Mudvayne's Avatar
Mudvayne is an unknown quantity at this point
Default RE: decelleration noise in 98 blazer
I would be checking the wheel bearings and front half shafts. At highway speed, swerve the vehicle lightly across the entire lane and see if the pitch changes from left to right. Report back with what happens. Dont swerve dangerously, just weave back and forth. Your trying to load/unload each side of the wheel bearings. If the pitch changes while swerving, thats is most likely the culprit.
Irish07
Oct 31, 2012 06:04 PM
Chrismacster
Apr 2, 2009 06:57 PM
GW
Engine & Internal
Jan 28, 2007 03:21 AM
picken_grass
Aug 1, 2006 04:54 PM
isfumpire
May 17, 2006 05:24 PM
