-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   Differences between LS and ZR2 (https://blazerforum.com/forum/general-tech-help-7/differences-between-ls-zr2-5375/)
mscott03 09-08-2006 09:37 PM
OK, So I've been searching the internet for a while now and cant seem to find out what on the ZR2's are different from the LS. I've never owned a non ZR2 model so I have no clue.. Does anyone have this information?
swartlkk 09-08-2006 09:44 PM
RE: Differences between LS and ZR2
Basically Suspension. The frames are different to facilitate the different mount points necessary for the factory lift that a zr2 comes with.
m00nwater 09-08-2006 10:36 PM
They only come in two doors, if that is something you might need to consider.
They also have skid plates, bigger, wider tires (I believe they come with 31's). They all come with wider flares because of that extra width, I suppose. The chassis is heightened and it has a wider stance. It can come in 2wd for some reason, which makes no sense to me because it's supposed to be an offroading vehicle. I'm not sure if all of them do, but I think they also come with a rear locker.
Basically, it's designed for offroad.
Hanr3 09-09-2006 04:11 AM
Everything you wanted to know about what makes a ZR2 different from a non-ZR2.
Click Me
mscott03 09-10-2006 02:55 AM
That was an awesome site - thanks for that one..
1996BZR 09-10-2006 03:30 AM
yea hanr very good site.
Brian J. Lesko 09-11-2006 05:18 PM
The ZR2 is an LS model. The difference between the regular LS and a ZR2 is the larger tires, fender flares, and a 3 inch factory lift. The ZR2 is also only available as a 2 door model. Also, the ZR2 automatically has a lot of options standard. (CD player, power everything, etc.)
Hanr3 09-11-2006 11:59 PM
Not sure what the trim levels on the ZR2 are, however the trim levels on the regular S10-Blazers are LS or LT. At least on the newer body styles. On the older body styles there was a Tahoe version, and a few others taht I canoot think of at the moment.
Each trim level determines the standard options on the vehicle. You can have other options added to the standard trim level. However they all start out as either LS or LT, at least for the newer body styles.
It could be possible the the ZR2 has both trim levels as well.
In essence
LS & Lt are tirm levels.
While ZR2 is a suspension package.
There are other suspension packages as well. However, most people don't talk about them much.
Brian J. Lesko 09-12-2006 09:09 AM
Not 100% sure, but I think that all ZR2's are the LS trim level. At least mine is, and so is my cousin's, and a few other people that I know that have or have had ZR2's. If there is a LT trim level ZR2, I've never seen one. Does anyone out there have one or know if it exists?
