General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Dim Headlights / Grounding Wire?
Old May 29, 2006 | 04:50 AM
phil01ss's Avatar
phil01ss is an unknown quantity at this point
Default Dim Headlights / Grounding Wire?
Hey guys, I have no dim headlights in my 2001 Blazer. Brights work fine, as well as everything else electrical. The DRL are working fine as well, and the light sensor that switches over at night is working fine, just not the darn lights. I checked the fuse in the fusebox, replaced both relays (Headlamp and DRL), tried another light switch (couldn't get a new one because of holiday), then I broke out the test light. It appears that I am getting power to the lights, so I assume the dimmer and headlight switches are OK. Is this a good assumption? Also, can anyone tell me where the ground wire comes from the headlights, and where it is atttached to the body? It's buried down in there pretty good.
Also, if anyone knows of a TSB on this, or where to find TSB's in general, the info would be appreciated.
Old May 29, 2006 | 09:21 AM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: Dim Headlights / Grounding Wire?
There's a link for TSB's at the top of the page.
maddzz
Jan 4, 2013 06:03 PM
NUM-1-GM-FAN
Apr 22, 2010 08:04 PM
Big O
Jan 31, 2010 09:29 PM
aspenchevy
Nov 10, 2008 08:28 PM
jaleg
Nov 17, 2004 02:53 PM
