General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Door handle broken
Old Nov 23, 2006 | 01:30 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Door handle broken
My passenger side door handle is weird, you need to pull down on the left side, then lift up to open it. My brother had the same problem in his 94, and my friend had this problem in his 92. Anyone else have this somwhat comon problem? Any ideas on how to fix it? Can't be too expensive. Thanks.
Old Nov 24, 2006 | 01:57 AM
Chevy Lover's Avatar
Default RE: Door handle broken
I'm guessing that this is the outer door handle on your '88.
It sounds like you need to replace it. It's fairly easy, just remove the door panel, remove the linkage, remove the screws that hold the hande in, remove the lock cylinder retainer clip and reverse the procedure to install.
[IMG]local://upfiles/2910/8D86596BDDC34FE4B44DC1969C2F73A6.gif[/IMG]
northlander
Oct 20, 2013 10:51 PM
scanlojs
Nov 4, 2010 04:51 PM
Tony H
Sep 28, 2009 01:45 PM
2002XTREME
Mar 21, 2008 04:18 AM
C5Longhorn
Feb 28, 2005 03:21 AM
