-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   Door Hinge Problem anyone??? (https://blazerforum.com/forum/general-tech-help-7/door-hinge-problem-anyone-2777/)
saxy37 Mar 10, 2006 02:24 PM
Anyone have problems with there door hinge(s). I am experiencing some give on the driverside. Is there an easy fix. My buddy has the same problem and I was interested to know if anyone else is in the same boat?
Jman Mar 10, 2006 02:56 PM
RE: Door Hinge Problem anyone???
They all wear out eventually. They are cheap parts. Just get together with your buddy and work together and do both at the same time. Fairly easy fix. The big spring on the upper door hinge fell out on my blazer and thats not such an easy fix. Someday I might get around to fixing it.
saxy37 Mar 10, 2006 04:30 PM
Thanks Jman. I guess just normalwear and tear .....but this is coming from someone who baby's his machine more than most others. I guess once the nice weather comes around....Ill have to spend a few hours and get it done.
DaveLance Mar 10, 2006 06:37 PM
This should help.
http://www.automotiveforums.com/vbul...d.php?t=476619
user 1016 Mar 10, 2006 11:56 PM
you could try lubricating...*snicker* lube.....anyways.....pouring on some lube helps in the long run...I have already had to replace my door hinges once...I am guessing cause my seals are bad....but I notice them squeaking every few months.....put some lube on em...and they work much better....just my little suggestion
saxy37 Mar 13, 2006 05:34 PM
Thanks for the info. Much appreciated
saxy37 Mar 13, 2006 05:46 PM
what a great help......thanks a lot
2001blazer Mar 13, 2006 09:22 PM
i had the same problem the door was sagging they said it was common i just replaced it there is a hinge kit that has the bushings and w/e else so it doesnt sag
vspeers1 Apr 24, 2006 10:10 PM
I had this same problem, and honestly let it go too long. This was the original reason i got on this forum and I looked at the link from DaveLance and it helped tremendously. Thanks for the help. Was an easy fix I should have done awhile ago. If you haven't done it yet and the problem is starting do it before it gets worse. Thanks again.
Victor
Dory Apr 24, 2006 11:40 PM
I just got the truck on Friday but I can hear the driver's door not very happy. I'll probably do this as well and while I'm at it sand down the tiny bit of rust and clean it up with some paint as well.
