Community
Search
General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Door Hinge Problem anyone???
Old 03-10-2006, 02:24 PM
saxy37 is an unknown quantity at this point
Default Door Hinge Problem anyone???
Anyone have problems with there door hinge(s). I am experiencing some give on the driverside. Is there an easy fix. My buddy has the same problem and I was interested to know if anyone else is in the same boat?
Old 03-10-2006, 02:56 PM
Jman is an unknown quantity at this point
Default RE: Door Hinge Problem anyone???
They all wear out eventually. They are cheap parts. Just get together with your buddy and work together and do both at the same time. Fairly easy fix. The big spring on the upper door hinge fell out on my blazer and thats not such an easy fix. Someday I might get around to fixing it.
Old 03-10-2006, 04:30 PM
Thanks Jman. I guess just normalwear and tear .....but this is coming from someone who baby's his machine more than most others. I guess once the nice weather comes around....Ill have to spend a few hours and get it done.
Old 03-10-2006, 06:37 PM
DaveLance is an unknown quantity at this point
This should help.
http://www.automotiveforums.com/vbul...d.php?t=476619
Old 03-10-2006, 11:56 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
you could try lubricating...*snicker* lube.....anyways.....pouring on some lube helps in the long run...I have already had to replace my door hinges once...I am guessing cause my seals are bad....but I notice them squeaking every few months.....put some lube on em...and they work much better....just my little suggestion
Old 03-13-2006, 05:34 PM
Thanks for the info. Much appreciated
Old 03-13-2006, 05:46 PM
what a great help......thanks a lot
Old 03-13-2006, 09:22 PM
2001blazer is an unknown quantity at this point
i had the same problem the door was sagging they said it was common i just replaced it there is a hinge kit that has the bushings and w/e else so it doesnt sag
Old 04-24-2006, 10:10 PM
vspeers1 is an unknown quantity at this point
I had this same problem, and honestly let it go too long. This was the original reason i got on this forum and I looked at the link from DaveLance and it helped tremendously. Thanks for the help. Was an easy fix I should have done awhile ago. If you haven't done it yet and the problem is starting do it before it gets worse. Thanks again.
Victor
Old 04-24-2006, 11:40 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
I just got the truck on Friday but I can hear the driver's door not very happy. I'll probably do this as well and while I'm at it sand down the tiny bit of rust and clean it up with some paint as well.
Quick Reply: Door Hinge Problem anyone???
