-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   egr valve or somthing (https://blazerforum.com/forum/general-tech-help-7/egr-valve-somthing-2818/)
khalid_20879 03-13-2006 04:43 PM
can a clogged egr valve cause my motor to stall out when you give it gas and also have no power?? Or does this sound like a vacuum leak or catalytic converter? Any advice sure would help before I go broke run back and forth to the shop
93LT 03-13-2006 06:06 PM
RE: egr valve or somthing
What year of Blazer are you talking about, what size engine. If you have the Vortec V-6, you can disconnect the wire harness from the EGR valve and and take it for a spin. You CE light will be on, and the EGR valve will remain closed, or as closed as it can if it is clogged. Do your brakes feel hard as a rock?
4lowlife 03-14-2006 04:23 AM
A vacuum leak can cause stalling. I know by experience.
