Engine code pulled
First a little bit of history on it. After i have been driving the 99 blazer for awhile, usually on long trips, I'll jump on the gas and the SES light will illuminate. Absolutely nothing feels wrong pedal/enginewise and then after a full warm-up and cooldown cycle or two it goes away. I had the guy at Autozone pull the code and he came up with a 101. His little flip book showed five things that could be wrong. A few of them were a dirty MAF, jacked up MAP or vacum hose leaking clogged or disconnected. Anyone else ever had this code or know of a book or something that could provide me a few details? Thanks for any help I know I'll get from you guys. Superpoo |
RE: Engine code pulled
Have you got the factory air box/cleaner or a cone style oiled gauze. If it is a K&N style with oil the MAF maybe needing a good cleaning. Clean it anyway if it has not been done then you should do it now... CRC chemicals makes a MAF specific cleaner...
I was planning on cleaning the MAF first. I started thinking back to when i first got the truck and remembered how filthy the paper filter was. I also remembered that the first time this happened was before i removed the old filter. I'll ask around town to see if i can find the cleaner. If not i'm jist gonna hit it with some compressed air for electrical components. Anyone else have any ideas?
Superpoo |
NO COMPRESSED AIR, the wires are easily broken. If you can't find the CRC cleaner then go to Radio Shack and get some electronic parts cleaner, that does not leave a residue.
Got ya!!! And thanks for the warning.
Superpoo |
Yeah, you are headed in the right direction:
P0101 - Mass Air Flow System Performance Most of the time this is caused by a dirty MAF sensor. And you don't have to have an aftermarket oiled air filter to get a dirty MAF. Also, I think we'll be seeing much more of this type of problem in the next few weeks/months as a dirty MAF sensor causes more problems the colder the temps get outside. |
