-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   engine light flashing (https://blazerforum.com/forum/general-tech-help-7/engine-light-flashing-5641/)
tammikm 09-22-2006 11:34 PM
on the highway tonight while passing a car the engine light began to flash maybe 6 - 10 times then went out, what does that mean? it is a 2001 trailblazer, and has never done this before.
thanks
20Blazer00 09-23-2006 02:03 AM
RE: engine light flashing
Have the computer scanned for DTC's. One indication is that there are cylinder misfires. And need to be taken care of. When was the last time the truck was tuned up, wires-plugs-cap-rotor etc.
tammikm 09-23-2006 09:27 AM
tuned up a year ago but just got plugs, should I have it looked at? its not flashing anymore.
20Blazer00 09-24-2006 04:18 AM
I would find someone with an OBDII scanner to see if the computer has stored codes, these don't set off the engine lights but are stored in memory, if the problem that caused the flashing engine light is not corrected or gets worse then it will turn the light on. If it fixes itself or was just a temporary situation the code will be removed from the computer after a predetermined set of "drive cycles". Some times this can be as little as three starts and stops or I have read that some codes will take 40+ "drive cycles" to self remove after setting the light... so if the light stays off in the same situation then the problem will have been temporary and the computer will not set a more permanent code...
AutoZone has been known by many to check codes for free...that is one avenue to get them checked without paying the dealer a fine for hooking up the scanner....
