-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   gear ratio's (https://blazerforum.com/forum/general-tech-help-7/gear-ratios-3975/)
ceanern 06-16-2006 10:20 PM
gear ratio's
alright Iw as reading up if I change tire size that it might be wise to change my gear ratio. What is the best way to find out what my gearing is? Would the VIN run at a dealership be able to give me that information or does anyone else know where to check? I have a 99 chevy Blazer 2dr LS model. I believe it may have a tow package but I"m unsure. It does atleast have a towing hitch. if anyone knows It would be greatly appreciated.
swartlkk 06-16-2006 10:46 PM
RE: gear ratio's
Your RPO listing will give you the installed gear ratio in your truck. The RPO sticker is on the glove box door and consists of many 3 character codes.
Here's a list of the gear ratio's available and their associated RPO code:
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
ceanern 06-16-2006 11:12 PM
RE: gear ratio's
by the looks of things I have the 3.42 anyone know where we can pick up new gear sets?
ceanern 06-17-2006 12:32 AM
RE: gear ratio's
Has anyone changed there gear seats? To match up to the tires they need? It is looking like i need a 4.64. Anyone know where I can find one?
swartlkk 06-17-2006 12:41 AM
RE: gear ratio's
What size tire are you putting on?
ceanern 06-17-2006 04:20 PM
RE: gear ratio's
Looking at 30's for now unless I get a lift. Be it either a suspension or body. Cause I'm already running rancho RSX on the front and rear.
tom1337 06-17-2006 07:03 PM
RE: gear ratio's
You can use the 3.42 and 3.55 w/ the 30's for best fuel economy. 3.73, 3.91, and 4.11 for a daily driver and best overall performace (power & economy). 4.27 and 4.56 for towing and power.
Here is a formula you can use: new tire size/stock tire size = % of change X original gear ratio = new gear ratio.
This will get you right around where you need to be.
4wheel parts will have all you need.
website
ceanern 06-17-2006 08:44 PM
RE: gear ratio's
That is where i was getting most of my numbers from. definately going to be checking them out more and more.
