General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
headlight level
Old Jan 30, 2006 | 12:33 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
Default headlight level
ok so i got the corner lights in and to do that u have to take off the headlight so i did everything but now both of my headlights are pointed up and i know that the left headlight is supposed to be down lower then the right is this a problem and if so how can i fix it by the way the corners and tail lights look sweet...next up tint rims and a bigger amp
Old Jan 30, 2006 | 10:18 AM
Whittaker's Avatar
Whittaker is an unknown quantity at this point
Default RE: headlight level
Pull your Blazer up to within inches of a flat wall on level ground. Mark the center of the light from your low beams on the wall. Back up until the front of the Blazer is 25 feet from the wall. Obviously you want the left beam slightly below the mark and the right beam on the mark.
That will give you a rough alignment.
Old Jan 30, 2006 | 10:45 AM
I'll also note that you'll want to have a 1/2 tank or less to do this. Also, here's the aiming criteria (less what was listed above) from AllDataDIY.com:
The top edge of each high intensity zone must be within 50.8 mm (2 in) above to 63.5 (2.5 in) below the horizontal centerlines. The left edge of each high intensity zone must be within 101.6 mm (4 in) to the left or to the right of the vertical centerlines.
I typically will center up the High Intensity zone of the headlamp on the Right headlamp with the vertical centerline, and position the zone for the Left headlamp just to the left of the vertical centerline. This gives a nice uniform spread over the entire road surface. I also always adjust them to be slightly below (~1.5" lower) the horizontal centerline when at 1/2 tank because when I load up the truck, the lights will go higher, but if you rarely load up your truck, then you shouldn't have anything to worry about centering them up to the horizontal centerline.
lemon blazer
Jun 28, 2007 07:46 PM
scottyk
Mar 25, 2007 09:19 PM
xtreme_ss
Suspension Tech
Jan 25, 2007 05:32 PM
blackknight
Dec 26, 2006 12:01 PM
nofear17bmx
Dec 22, 2006 04:38 AM
