Hesitation
I have a 2000 Blazer 2dr. 4X4 5-speed with 75,000 miles on it. When I am at a comstant RPM while driving every once in a whil I will get a moderate hesitation. I have also noticed it during steady acceleration too. Replaced MAP sensor, fuel filter, cap & rotor, plugs, wires, cleaned throttle body. I noticed it about a month or two after I installed a K&N cold air intake on it. Looking for any help I can get
RE: Hesitation
Clean your MAF, if the K&N had excess oil then the MAF will get coated with not only the air cleaner oil but dust and dirt to....primary cause of these symptoms.
RE: Hesitation
you might want to check that the EGR valve is clean also.
RE: Hesitation
Could be a EGR valve sticking as stated by Chevy Lover. Remove it and give it a good cleaning. You may want to try some SeaFoam too.
RE: Hesitation
Replace your fuel filter.
