-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   How do ya... (https://blazerforum.com/forum/general-tech-help-7/how-do-ya-3466/)
Dory 05-06-2006 11:35 PM
How do ya...
Get the darn truck in Auto or 4wd high?? hahaha! I never had a truck, so this is all new to me, do i have to be in neutral, drive, foot on brake, what? I hit Auto 4WD and it blinks and then returns to 2WD. Not a damn clue! HELP!
Dory 05-06-2006 11:45 PM
RE: How do ya...
Forgot to mention I've had it in 4wd once "on the fly" but not sitting still.
swartlkk 05-06-2006 11:48 PM
RE: How do ya...
This sounds like the dreaded controller problem... Will it go into 4lo? When attempting to go to 4lo, you should be stopped and in N on the gear shift lever.
*EDIT* - you don't have to be stopped when switching between hi range options (2hi to 4hi or vise versa). Speeds in excess of 45mph are frowned upon for switching into or out of 4hi, but anything in between should be fine. Hopefully it was just the positioning of the drivetrain that caused it to fault out and return back to 2hi. Try it again while moving a bit and see if it works.
4lowlife 05-07-2006 04:49 PM
RE: How do ya...
4low rocks!!!!
Dory 05-08-2006 10:54 AM
RE: How do ya...
UGH! I cant get it into anything except 2wd!!!!!! [:@][:@][:@][:@][:@][:@][:@]
I've tried sitting still, moving, neutral, reverse, brakes on and off... nothing. I'm going to have to get it looked at. [>:][>:]
MCas86 05-08-2006 11:18 AM
RE: How do ya...
that sux, hopefully its something cheap.
Dory 05-08-2006 11:21 AM
RE: How do ya...
oh yeah... keep your fingers crossed!!! [&:]
BRODIE 11-24-2006 01:41 PM
RE: How do ya...
WHAT EVER HAPPENED WITH YOUR SITUATION BECAUSE IM IN THE SAME ONE! PLEASE BE CHEAP! PLEASE BE CHEAP!
