Leaking inside truck
ok i was driving around last night and it was raining. on of my buddys was in the back seat and he looked up at my dome light and noticed water in it. So we pulled it down and its wet on top of the headliner. He said something about maybe the drain tio the sunroof is clogged? is this a possible? any help would be nice lol
RE: Leaking inside truck
Yup, if you have a sunroof, then its possible a drain is clogged. Other areas to check would be the mounting screws on the rack...
where do i have to check for the drain?? its not under the headliner is it?
There should be a drain hose off each corner of the sunroof. The front ones go down the 'A' pillar and the rear ones go down the 'B' pillar. And yes, they are above the headliner. You should be able to pull off the trim on the 'A' & 'B' pillar to see them on that end, but it is also possible that one of the hoses have come unhooked...
