Light Seal
Alright uh Im havin alot of trouble with the Xtreme's foglights. I need to get the front clear peice off but i cant convinve the clip to come loose to remove the clear peice!!!!
Can i like heat it up abit with a flame or something and see if it loosens up or will that damage the housing. It really doesnt look like it has a seal on it. Just really tight clips help pls |
RE: Light Seal
Why do you need to remove the lens?
all I can see si that the foglight comes out as a unit. Disconnect the electrical connector. Remove the push pins. Remove the adjustment screw. Remove the foglamp from the vehicle |
RE: Light Seal
He wants to install halo's in his fogs...
