Morning starting problem...
This has been going on for a while now, now that its getting cold. What happens is I go to start... CRANK CRANK CRANK CRANK CRANK, boom, stall, CRANK CRANK CRANK CRANK, boom, almost stall... gets going then. I didn't really think it was a big deal because it drives great, but snow is comming and its prolly just gonna get worse. It got a new dist. cap, plugs, wires, etc. when it was rebuilt. Any other suggestions? Also, it doesn't stall everytime on the first start up, but wants to. Thanks in advance.
RE: Morning starting problem...
Check the fuel pump pressure, coolant temp sensor and throttle position sensor
my '88 with the 2.8 and 5-speed had similar starting problems when cold. the guy i gave the engine to when the truck was parted out said that replacing the fuel injector fixed the problem.
Had a 3.1 Throttle body with simular issue.
Cleaned out the bowls and injectors (due to the second one seemed not to be spraying right) And that fixed that. But if I were you I would do that (if its TB) and check the TPS (throttle Possision Sensor) also |
