General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
No drain plug!!
Old Nov 5, 2006 | 01:03 PM
mellon101's Avatar
mellon101 is an unknown quantity at this point
Default No drain plug!!
First of all, I am a new blazer owner. I just want to say thanks for the wealth of information in this forum! It has helped me tremendously so far.
I was planning to change the oil in my front diff this morning, but there is no drain plug!!
I have two different fluid pumps, but neither has hoses small enough to snake down inside to pump out the fluid.
On the passenger side, there is a triangle shaped thing bolted there. Looks to be a sensor of some sort...and maybe the speedo cable??? Could I just remove that to drain it??
I will attach a picture of each side. Am I missing it???
Thanks
[IMG]local://upfiles/4100/6580253D711549AD9CEB7AD2F53D99FF.jpg[/IMG]
[IMG]local://upfiles/4100/676FF810A0AF459C97BB3CC73B81D892.jpg[/IMG]
Old Nov 5, 2006 | 02:46 PM
Chevy Lover's Avatar
Default RE: No drain plug!!
Welcome to the site.
I was trying to edit your pic to point out the drain bolt....no success
The bottom bolt in your second pic should be the drain bolt...it's a 13mm with a washer on it.
[IMG]local://upfiles/2910/7DDC664421084F94B4875E765D447D2B.gif[/IMG]
Old Nov 5, 2006 | 07:57 PM
mellon101's Avatar
The bolt you are talking about goes all the way through the case and is exposed on the other side. Definitely not a drain plug.
The image you posted is different from my case.
It shows the plug being on the driver's side. The first picture I posted was the driver's side.
Very strange. Sucks to be me.
Old Nov 5, 2006 | 08:24 PM
I don't know what year pic I posted, but I guess I wasn't to sharp, sorry.
I don't have info for a 96.....so...how about the bolt directly below the filler plug. If not, then try a suction pump. I bought a suction pump for about $10 and it's served me well on many occasions
I have installed a tapered nipple on the end of the hose to use as a reducer to add a smaller diameter hose also.
Old Nov 5, 2006 | 08:42 PM
mellon101's Avatar
I have a pump ....I will just have to get some small hose and a tapered nipple like you said.
thanks for the help
boulonman
Mar 5, 2007 05:10 AM
MCas86
May 11, 2006 07:40 PM
HCCAFan
Mar 14, 2006 06:30 PM
eng69
Feb 13, 2006 03:08 AM
2001Blazer4x4
Mar 2, 2005 10:45 PM
