Oil leaking?
I don't think it burning off. I'm pretty sure it's leaking. But not really sure from where other than it's on the drivers side.
Last Sunday I put a bottle of "No Leak" and 3 quarts of oil. I'll check how much is left tomarrow cause it's not here right now. Is there any places that are prone to leaking more than others? Oh it's got 164K miles |
RE: Oil leaking?
Hmmm...most common oil leaks, the oil filter adapter lines from the engine block to the oil filter. Rocker cover gaskets and engine oil pressure sender. Let's hope it's not the rear main engine oil seal.
The engine oil drain plug gasket. |
