rear brake rotors
does anyone know how to get the rear break rotors off a 99 blazer... i got the front two done and cant for the life on me figure out how to get the rear off
thanks tim |
RE: rear brake rotors
Most likely the internal drum parking brake is hanging up. You are going to need to try and pull out while turning the rotor. Hopefully it will get past the rusted lip on the internal drum hat...
*EDIT* - Here's my post on the subject: Rear Disk Brakes... |
so if i just yank the rotor of it wont like mess up the e brake will it?
It might help to adjust the park brake cable for more slack first. Also, push the park brake lever closer to the backing plate if you can, (sometimes the cable sticks a bit). Kyles' probably right that the rotors are hanging up on the shoes internally.
If you pull the rotors off and the shoe comes out with it, the only damage will probably be to the clip that holds the shoe to the backing plate. That little spring clip is replaceable. |
