rear defroster
One of the spiral wires that hook to the rear window to heat the defroster has come off. What do I use to get it to stick back on yet let the defroster work?????
RE: rear defroster
Did the whole spade terminal break loose from the glass? If so, then you may have to solder it back on to make contact again...
RE: rear defroster
Yes, the whole thing came loose. I know this may be a stupid question but you can solder on glass???[8D]
RE: rear defroster
No, you will have to bond it using an epoxy (after roughing up the glass with some sand paper in that area), then solder the joints that lead to the heating elements.
I'll have a look at mine to see how it may be done other than what is listed. |
RE: rear defroster
I had this same problem, the dealership said it had to actually soldered and gave me the instructions and part numbers. However all I needed was the solder past kit, just don't sand too hard. Here is a link to a good suplier for the material you need Frost Fighter
