rear end shudder
anyone know what would cause a shudder in th erear end off a take off but only when turning a corner from takeoff.. shudders for a few seconds then its fine.
had a u joint replaced but its still the same thanks |
RE: rear end shudder
I think mine does that , very minor but i do feel it there. What year is your blazer ? I feel it most on mild to hard take off.
its a 2001. i feel it on every take off if i have the wheels turned as i take off
Have your rear differential fluid changed. You most likely have the "G80" RPO (locking rear differential).
I have a 2001 Blazer Xtreme and mine did that shuddering thing for the first six months until I finally figured out it was the rear diff fluid that needed to be changed. I had it changed around 7,000 to 10,000 miles and to this day, I haven't heard it again. I'm now at 76,000 and I've had that fluid changed every 15,000 miles. |
I had the rear diff fluid changed and it still has the shudder on acceleration but mainly only when I have the wheels turned and take off from a stop....also feel it a bit on straight take off if I accel hard...
| All times are GMT -5. The time now is 09:15 AM. |
