Right parking lamp problems.....help
well my passenger side parking light (underneath headlamp) is acting up for some reason when my lights are on it does not light up like it should, but when i use my right turn signal and seems to be working just fine. Does anyone know what the problem could be?? thanks
Danny |
RE: Right parking lamp problems.....help
Welcome to the forum.
Try replacing the bulb. It's a dual filament bulb, only half of it's working. |
Yup what he said. get new bulb
Thanks guys!
If that doesn't work, you may need to clean the contacts in the bulb socket. I haven't had mine apart to know how the socket is arranged, but if it's like the taillight socket, it can be completely disassembled and cleaned properly. I would recommend using some dielectric grease down in the socket to protect the contacts.
Again, that is if the new bulb doesn't really help things, or it starts doing it again after replacing the bulb. |
yup turns out it was the light..thanks again guys
