General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rust
Old Aug 14, 2006 | 04:43 PM
docmoody's Avatar
docmoody is an unknown quantity at this point
Default rust
i got lots of rust on the front fenders, bumper and doors what is the easiest way to fix it. And my blazer is a 94 how do i recharge my ac.
Old Aug 14, 2006 | 06:45 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: rust
I would just go and get what you need from your local junk yard.
Old Aug 14, 2006 | 11:41 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: rust
NAPA sells fenders for about $80 each. They come primered and I believe NAPA also sells the matching paints you would need.
Old Aug 15, 2006 | 10:13 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: rust
if you can find decent stuff at a junkyard that is the way to go. stock parts fit so much better than aftermarket its unbelieveable.
doors, my advice is to make sure the drain holes in the bottoms of the doors are not plugged up causing the water to sit in the door and rust from the inside out. replace window scrapers if necessary. then get a can of masterseries paint (www.masterseriesct.com). grind down the rust, paint with masterseries, then go about doing the normal bodywork stuff (bondo, sand, paint). do not just use any old primer or try to bondo right over the rust, this does NOT work. you need to seal the rust with masterseries or por-15. i prefer masterseries because its easier to work with IMHO. por-15 might be easier to find in your local hardware store though.
fenders and bumpers are throwaway parts IMHO and arent worth fixing, but you can take this route with them as well. but its less aggrivating if you can find a nice set of fenders at the junkyard and just bolt them on.
Chic_Bowdrie
Mar 31, 2012 08:47 AM
snowman
Apr 5, 2007 09:12 PM
yeags
Detailing
Dec 7, 2006 02:00 PM
mistasmiff
Detailing
Aug 30, 2006 11:57 PM
BlazerSquad93
Headers, Intake, & Exhaust
Mar 4, 2005 11:25 PM
