-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   starter solenoid?? (https://blazerforum.com/forum/general-tech-help-7/starter-solenoid-6821/)
97blz4x4 11-23-2006 09:26 PM
starter solenoid??
Hey yall i have a 97 s10 blazer 4x4 and i cant find a starter solenoid anywhere.What store can i find one at on the web and in person and about how much do they cost????
97blz4x4
Brandon
1996BZR 11-23-2006 11:01 PM
RE: starter solenoid??
I believe a starter solenoid is located directly on the starter and to get a new one you have to buy a new starter.
Crashes 11-24-2006 12:29 AM
ORIGINAL: 1996BZR
I believe a starter solenoid is located directly on the battery and to get a new one you have to buy a new starter.
Are you serious? The starter Solenoid is on the starter, and you can get one at any autoparts store, but your better of getting the whole starter, cause it could be your actuator going out (what pushes the cog out of the start to hit the flywheel)
Btw, your looking at about 50 bucks for a cheap one, a starter probably runs about 80 bucks (Im guessing about the starter price, I know the older 4.3ls are cheap)
Chevy Lover 11-24-2006 01:47 AM
Yes, the solenoid is mounted on the starter motor. I would agree that it's probably a good idea to replace the whole starter. I just think that if the solenoid is failing, that the starter motor is the same age and also has worn brushes.
Why pull the starter off twice, just replace the whole thing once and forget about it.
1996BZR 11-24-2006 03:17 AM
ORIGINAL: Crashes
ORIGINAL: 1996BZR
Are you serious?
I am truly sorry for saying battery, I meant starter but was thinking about myself having to buy a battery today....brain fart on my part. really didn't mean to put battery....I was reading and thought "what dummy would say it's on the battery but say to replace the starter" then saw that I posted that. Ha You can kinda tell I meant starter since i said you would have to buy a new starter and mentioned nothing about the battery. anyway, it's fixed now.
Crashes 11-24-2006 08:04 AM
ORIGINAL: 1996BZR
ORIGINAL: Crashes
ORIGINAL: 1996BZR
Are you serious?
no problem :D dont worry, we all do it
