-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   temp reading on overhead console (https://blazerforum.com/forum/general-tech-help-7/temp-reading-overhead-console-3595/)
DaShark 05-16-2006 04:32 PM
My overhead console temp reading shows OC....anyone have this problem and if so, how do I fix it. Cant seem to get it to reset at all. It seemed to work fine and then wouldnt register over 50 degrees and now shows nothing but OC...any help will be appreciated....just joined and seems like a great spot....
DaShark
hillbillyinOhio 05-16-2006 05:30 PM
RE: temp reading on overhead console
The OC means out of calibration. Could be one of three things, either the ambient temp sensor, mounted on grille is bad, broken, or the wiring is F'd up.
DaShark 05-16-2006 06:13 PM
Thanks Hillbilly I will check that out....can you order parts for that from any auto store?
