Transmission Swap
I have an 82 blazer and i need to swap out the transmission, but the trans i have is off a 2 wheel drive and my truck is 4wd. How do i connect it to the transfer case? |
RE: Transmission Swap
bump
HOLY IMPATIENT MUCH!! Please do not *BUMP* a thread that is only minutes old. Don't even bother until it's over 24hours old.
But to answer your question... Basically you need to swap the tail shaft. In the early 700R4's which I believe you have, you basically have to remove the entire guts from the transmission to do so. |
| All times are GMT -5. The time now is 02:17 PM. |
