-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   Vacuum line? (https://blazerforum.com/forum/general-tech-help-7/vacuum-line-6689/)
dusted800 11-17-2006 12:07 PM
Vacuum line?
I am still having trouble with my 4wd. I found a rubber line 7/32 that comes out above the brake booster on my 95 blazer. The other end is attached to the black plastic ball that is mounted to the underside of my hood. The problem is I don't know where this is suppose to attach to. It heads toward the back of the engine. Can anyone help me with this? thanx. wnk.
Chevy Lover 11-17-2006 01:09 PM
RE: Vacuum line?
It probably heads towards a plastic vacuum tee on the passenger side of the transfer case.
There is a vacuum switch on the upper right side of the transfer case that is fed by that vacuum hose....I believe.
dusted800 11-17-2006 01:41 PM
RE: Vacuum line?
This line does not have any vacuum when I start the vehicle. I am assuming that it must plug into some sort of vacuum source?
mellon101 11-17-2006 06:32 PM
RE: Vacuum line?
I do not know exactly what you are driving ....but on my 96 if you follow the hose from the PCV to it's source, the source for the hose you are talking about is directly below it.
