wiring harness
has anyone had problems with the fuel pump wiring harness?i replaced the 4-wire harness when i installed a new pump...well that was 2-months ago...my gauge started jumping
back and forth just last week e-f...never reads correct...I'm thinking the other is bad...99 bazer |
RE: wiring harness
Check your connections. It doesn't take much corrosion to screw up the wiring. Did you shrink wrap the connections? If not, that may be your problem.
