HELP Please!! Trailblazer Fuel Sending Unit
hahahha wow didnt even notice the date...whoooops
I had the exact same problem as mladsig on my 05 Trailblazer LT 2WD.
Erratic readings, and when the fuel level was below 1/2 full, the needle would sit on "Empty" with the amber light staying on. My local Chevy dealer wanted to replace the fuel pump for $750 !
After reading this forum, I went to Athens Chevrolet in Georgia, and they replaced the fuel level sensor (p/n 19177712 SEN KIT 3.107 $118.62) with labor $270.00 for a total of $398.86
This fixed the problem!! Thanks!
Thanks for the report. I am glad you were able to find the sender for less than I had originally posted it costing.
If you have not started using Chevron Techron Fuel System Treatment Plus at each oil change, start now!
Fuel Sensor Part Number
I am having the same issues as everyone else here...I think I found the part needed from AC Delco:
http://www.rockauto.com/catalog/rafr...a=FR343-SK1158
Correct me if I'm wrong but this could solve the issue....just not sure I want to drop the tank myself
Would this part also be called a "Fuel Tank Pressure Sensor"? I found one at Autozone and wanted to make sure it was the right thing before I get it.
AC Delco SK1158 (replaces OE #88966954, #19178477, #88966954) is the fuel tank level sensor. Not the fuel tank pressure sensor.
Do you know what the part number is for a 2000 V6 Blazer with the TrailBlazer package?
native74warrior
TrailBlazer GMT360/GMT370 (2002-2009) Tech
07-17-2012 04:41 PM
2manybroke
12-30-2007 07:59 AM
