Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
1994 GMC Jimmy problems
Old Oct 27, 2023 | 12:15 PM
TheGreenTurd94's Avatar
TheGreenTurd94 is on a distinguished road
Default 1994 GMC Jimmy problems
Hey, I’m new to the GMC/Chevy Jimmy/Blazer field and I have bought a 1994 Jimmy and it has some engine problems but I bought it because it was an upgrade from a non running 84 f350 I have very little knowledge on the 4.3l vortec engine.
THE PROBLEMS
  • When I turn it over it starts to die out and come back while the oil pressure gauge goes up and down it fixes itself somewhat when I take the tps sensor out for a few seconds and put it back in after a bit it will continue the ruff idle
  • when I depress the throttle it will bog and stay at 10 mph before I had put new spark plugs and wires in it I had to bog it and let off fully and then it would go into second gear
  • the guy I bought it off of said he put sea foam in it to clean the injectors and I think the cat might be clogged
  • it sounds like there’s a vacuum leak on the intake I will have a video
  • the breaks let’s out air loud and you would have to depress it with all your strength and after a bit it will go to the floor
Old Oct 27, 2023 | 12:18 PM
Default Video
Video of the engine running
File Type: mov
Frank Bukowski
Mar 25, 2019 03:57 PM
allen
Oct 12, 2010 08:48 PM
2002XTREME
Aug 17, 2009 07:56 PM
elementalnature
Dec 26, 2008 09:32 AM
