-   Headers, Intake, & Exhaust (https://blazerforum.com/forum/headers-intake-exhaust-10/)
-   -   4.3 Backflow and sound (https://blazerforum.com/forum/headers-intake-exhaust-10/4-3-backflow-sound-101133/)
braden737 Apr 12, 2025 11:51 AM
Originally Posted by El_Beautor (Post 756658)
I've had a dynomax 2.5" cat-back setup on my Sonoma for about 6 or 7 years now, and quite like it. It has a nice full sound at idle and driving around town, but no drone on the highway. Definitely don't expect a cammed V8 rumble, but it's a more full & deeper sound than the factory exhaust. Mine is only mildly louder than the factory exhaust.
As for any performance changes, the headers, cats, and the Y-pipe are the major restriction points in the exhaust, so unless you replace everything I wouldn't expect any major changes in any performance metric. Because those are all upstream from the muffler, the muffler and larger down-stream cat-back tubes won't change anything with the back-pressure.
As for MPG, I did not notice any change to my fuel economy with that mod.
Can you use the stock tail pipe with the dynomax muffler?
El_Beautor Apr 14, 2025 09:44 AM
You can do anything if you are decent with a welder. Lots of places where you could find size adapters to adapt the muffler output to the factory 1.75" pipes. The smaller pipe would likely result in a fairly quiet exhaust. Personally, I have a custom 2.75" pipe downstream from the muffler to the fender behind the rear passenger tire, similar to the routing of the factory exhaust.
