explanation of exhaust system
can u tell me is the exhaust system {from) intake and exhaust manifolds 2 muffler ? (92 s10 blazer 4.3 vortec ) and can it changed 2 dual exhaust and what kind of PERFORMANCE difference could i see if any?:icon_playing:
For enough money (custom at an exhaust shop) you can get whatever exhaust you want. A dual exhaust would probably hang down pretty far. I don't think there is enough room under a blazer to get duals tucked up nice.
As far as performance, a dyno might show 10 h.p. at an unusable, high rpm level. Your butt probably won't be able to tell. Now, if you have a hotter cam, headers, an aggressive pcm tune, things of that nature, an exhaust upgrade becomes more beneficial, because you have done things to actually improve airflow through the engine. |
if anything if you have a mostly stock engine and you put true duals it will do more harm than good
Just run a slightly larger single pipe to a single muffler with two exits, if the look is what you want.
