FLOWMASTERS or MAGNAFLOW?
Trying to decide what I should go with for my exhaust. Any suggestions?
1997 Blazer 2dr 4.3 4wd auto |
depends on what you want.
People on here usually go with the flowmaster 40 series or the flowmaster super 44. Personally i dont think magnaflow's sound good. I have the 40 series and it sounds nice and deep. heres what mine sounds like revved to about 2000 rpm. It still sounds deep past 2000 rpm also. this was before i added the high flow cat 97 blazer 40 series muffler - YouTube |
What size pipe are you running after the cat?
3 inch. It makes it sound a little deeper and throatier
Edit: heres a link to my before and after videos: High flow cat: Before and after |
That wont cause any backpressure issues or anything with my rebuilt engine will it? Im hoping to send it to the shop this week and yours sounds, well, badass
Originally Posted by swartlkk
Backpressure being required for an engine to operate properly is a myth. There can never be too little back pressure. There is such a thing as an exhaust that is too large however. Basically, you want the exhaust sized appropriately such that the scavenging effects are maximized. Scavenging is when one exhaust pulse pulls along the next as they travel through the exhaust pipes. Too large of an exhaust and the pulses slow down too much when they expand in the large tube and do not have enough momentum to aid the next pulse. This is what happens when people throw on a large exhaust and loose low end torque.
Unless you have done things to shift the power or torque higher in the RPM, you don't need anything larger than a 2.5 through out. The reason why the factory pipe necks down after the muffler is because of how much the exhaust gasses have shrunk due to cooling. Going 2.5" all the way will improve the top end without changing the low end. |
Originally Posted by Dolanjohn1990
(Post 498207)
But with my set up i think i gained a little power because i also have a CAI |
Sweet. Im thinking a magnaflow high flow cat with a flowmaster super 44 muffler tied by 2 1/2 inch pipe is what im gonna do. Thanks for the input
That whole back pressure thing is complete bs. Complete myth. The only people who need to worry about back pressure are people with carburetors.
The only reason I didn't go with bigger piping is because I'm trying to "control the sound I want." I'm the guy you hate because I like loud exhausts (as long as it sounds good, the louder the better to an extent). I let the horses sing! :) But yea, the flowmaster super 44, 40 series, and 10 all sound good. |
[quote=97cherryblazer;497543]I have the 40 series and it sounds nice and deep.
I just picked up a 96 S10 Blazer 4x4 with stock exhaust and i'm kicking some ideas for when the necessary things are fixed. IMO results don't always equal money spent. Is your entire setup Flowmaster or just the muffler, its sounds like you built it up over time. And does a hi flo cat make a real difference? I like a good throaty sound, not maddening loud with some HP kick up. |
Heres the sound difference on mine: High flow cat: Before and After
I think it makes a nice difference, not a 300$ difference tho. I only upgraded to the High flow because my stock one got clogged, and i figured it was a good time to upgrade. so yes i did build it up over time. Its a MagnaFlow High Flow Cat and its 3" pipe from the cat all the way back. and 40 series muffler of course. |
