Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
high flow cat
Old Mar 30, 2007 | 01:10 AM
jagblazer01's Avatar
Default high flow cat
looking into getting a cat-back exhaust system for the blaze and i need to find somewhere to get a high flow cat. local shops charge a butt-load of money for them and stylin concepts do not carry them. any ideas?
Old Mar 30, 2007 | 02:57 AM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
Default RE: high flow cat
just search for them online i found a magnaflow cat for my camaro on line it only cost like 100 with shiping and everything
Old Mar 30, 2007 | 04:23 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
are they legal ?
Old Mar 30, 2007 | 05:33 AM
Zygoat's Avatar
not as far as i know, i believe on an EXTREME technicality it has to be the exact same type as the vehicle was originally constructed and it has to be in the exact same place. however you should be able to pass emissions just fine, i did with my camaro, before and after i installed my magnaflow cat, with the same results.
Old Mar 30, 2007 | 05:36 AM
Zygoat's Avatar
fyi for everyone out there, the cat is considered a part that is supposed to last the life of the vehicle "usually ten years" if it breaks before then the company that built it (gm) is required by law to replace it. this came with the paperwork for my magnaflow cat, mine was over ten, and i got better performance from the new one so i didn't care, as i imagine you don't but just letting everyone know.
Old Mar 30, 2007 | 09:44 AM
You can pickup a magnaflow universal cat for around $60 and just have it installed. These units will flow a lot more than the stock catalyst.
However, with any aftermarket catalyst, the post-cat O2 sensor may not like the difference...
And although it may be technically illegal to remove a perfectly working catalyst and replace it with another one, that can be argued and I've never seen anyone get in trouble for it. I have seen someone get a hefty $5000 fine for not having a catalytic converter though.
Old Apr 4, 2007 | 05:30 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
What differences would I see in replacing the cat with maybe a universal magnaflow cat and how would I correct the post cat O2 sensor problem?
Old Apr 4, 2007 | 05:50 PM
Zygoat's Avatar
it will free up your exhaust gas flow, as far as performance goes i doubt that it will make a noticable improvement although it depends on what other mods you have done. for example if you had a cold air intake, new muffler exhaust headers and y-pipe and the cat was your main restriction then it would probably make a big diffrence. as far as the o2 fix i dont know if their is much that can be done short of a spacific computer tune.
blazinbman
Performance & Brainstorming
Mar 12, 2012 06:35 PM
97cherryblazer
Feb 20, 2012 05:19 PM
Kknd310
Nov 20, 2010 06:43 PM
Deezy Steez
Mar 31, 2010 04:50 PM
BSchmity69
Jan 30, 2008 04:50 PM
