Installed cold air intake
Well today I got my CAI and put it in, it was fairly simple and took about 25 minutes... I like it and no matter what other people say I can notice some more power then the stock system...(could barely do a burnout before, now she does it with ease) I am overall satisfied, and was deffinetly worth th 45 bucks. I would personally recommend it, it was off eBay and made by a company called Chrome Intakes. I will post some pictures tommorow after I do my hinge pins.
Ok i got some pictures, and today after putting in hinge pins for the door i wrapped the whole pipe in heat sheild, all i have to do now is make a sheild for around the filter...
Here ya go: http://i1013.photobucket.com/albums/...t/DCFC0033.jpg http://i1013.photobucket.com/albums/...t/DCFC0032.jpg |
Not to sure how effective the insulation will be as far as improvements, but I will say it will cause the intake to rust in rather short order. That thin chromed steel will be gone before you know once a bit of moisture gets in the insulation.
its most likely a polished aluminum pipe kit
| All times are GMT -5. The time now is 11:24 PM. |
