Intake with TBS
I was thinking of installing a AEM intake on my 02 jimmy, only thing is would the height increase from my throttle body spacer cause any problems? Also I have a 2"body lift which I know may cause an issue with mounting.
since you have the body lift im fairly certain you wont run into problems with the height of the intake youll just have to fab up new brackets for the mounting process or figure out a way to use the supplied hardware.
So you do have the body lift installed? It should be no problem then...
Ya the body is installed already, ya I guess i'll do a little fabricating and I should be good
