-   Headers, Intake, & Exhaust (https://blazerforum.com/forum/headers-intake-exhaust-10/)
-   -   mass airflow sensor (https://blazerforum.com/forum/headers-intake-exhaust-10/mass-airflow-sensor-1540/)
BlaZeR FXB1581 Nov 13, 2005 01:03 PM
mass airflow sensor
wat does the mass airflow sensor actually do.....is it important?does it need to be ther?
swartlkk Nov 13, 2005 01:20 PM
RE: mass airflow sensor
It is an integral part of the engine. It tells the engine how much air is coming into the engine. It can not be removed! I believe that MAF sensors are heated element sensors and, by the cooling effect of the air, they produce a voltage drop across the sensing elements. They are ECU (engine control unit) is calibrated to the MAF sensor in its original configuration (ie. with MAF screen and cross-sectional area of the MAF assembly - 2 aluminum peices and the sensor itself). Removing the screen and/or porting the aluminum peices can cause incorrect readings to be sent to the ECU and may cause a lean condition in the engine. It mostlikely will throw a code as well.
Do you have a bad MAF? Or are you just trying to learn? Just wondering what prompted the questions?
BlaZeR FXB1581 Nov 13, 2005 03:41 PM
