Swiss cheese airbox mod
New to the forum, was looking around for some cheap/easy performance mods. I've seen quite a bit of controversy over cold air intakes (some say they work great, others say they actually hurt performance).
I've found a few threads about the "Swiss cheese" airbox mod which basically turns your stock box into a cai. This is achieved by cutting a 3" hole in the airbox, then running a PVC (or other material) snorkel to somewhere with cold air. As this seems like a very easy/cheap mod to do (as well as a very old one) I was wondering if anyone could vouch for performance gains/losses? I have a 1998 4.3 liter 4wd 4 door blazer if that makes a difference. |
The factory airbox is already a CAI. If you look at the plumbing it is pulling air from in front of the radiator support. In my opinion, unless you get the parts for the CAI for under $50 it's not really worth it. All it really does is make your engine slightly louder when you stomp on the throttle.
(Post 672577)
The snorkel from the box to the core suport is the restriction but it's true cold air. I left it alone and added three 1" pieces of clear tubing from the front of the box thru the core support to reduce the vacuum in the box. Seems like dinky hose but three of them in addition to the stock snorkle gave it a nice bump in feel and it's all cool air from outside the engine compartment. The stock hole in the core suport was port matched because it did not line up perfect then enlarged for two hoses. An existing hole outside of the headlight bracket was reamed out for the third.
I'm not sure what CAI is and only pix would clear up talk about holes and clear tubing for me.
Originally Posted by DARK1
(Post 673771)
http://[IMG]http://i67.tinypic.com/k3xao7.jpg[/IMG] http://i67.tinypic.com/k3xao7.jpg |
Originally Posted by Stumpalump
(Post 673781)
I'll post you a pic of the simple tubes I added to the Blazer if this rare desert rain ever stops.
Originally Posted by LoneWolf71
(Post 673891)
I would like to see pics of the blazer as well please.
http://i63.tinypic.com/n5re6v.jpg I put ball point pens in the tubes so you can see the clear tubing. I removed the box and drilled thru the front for each tube. There is room for at least 2 more tubes down low that could be added later. Picture of inside of the stock air box with the three clear tubes entering obove the stock snorkle. http://i67.tinypic.com/2v98z7s.jpg From the top down with the lid on you can see one tube slipping past the resivior. http://i63.tinypic.com/2w4fzo3.jpg Thru the core suport your results could vary but this is what I did. The tube on the right of the photo is the one you can see in the last photo. I enlarged an existing hole with a die grinder. The long oval hole I enlarged below it wound up being in the way of the headlight clip so don't use it. My factory snorkel came out way low of the factory opening for it. I enlarged the bottom of that hole so the snorke gets full air flow. I enlarged the top of the hole to run the other two hoses. I trimmed the bell on the end of the snorkle to give the hoses a nice place to sit. It was getting dark on me and I just wanted to wrap up a little more air flow but I believe if you put one hose below the snorkel and drilled the core suport it should fit. Edit: It fits. See next post. http://i66.tinypic.com/2yy81g8.jpg There is more than one good way to skin a cat. This was free, fast, keeps sound down, looks stock and actually adds true cold air from the highest pressure area of the vehicle. I'm happy. |
Just got done a driveway front end alignment to keep the General Grabber AT2's happy and decided to add more tube. One more is easy to add under the snorkle but for if some reason you want more you would have to go thru the bottom of the box. It's enough tinkering to get 4 tubes lined up an in their proper holes so I'm calling it done. Here is the hole I drilled and tube with pliers shoved in it.
http://i66.tinypic.com/k0hkb7.jpg Pic of inside of the airbox. Addition 4th tube comes in below the snorkel. Now it's got four 1" diameter tubes along with the factory 2" hole. Not sure of the math but it's got to at least double the air to the box. Any math experts here? http://i67.tinypic.com/155rmae.jpg |
Nice, thanks for the pics! Nice tires too! So did you feel or gain anything by doing this?
