1.5" Torsion Bar Crank and 2" Body lift
So i am thinking of doing a 1.5" Torsion bar Crank and 2" Body Lift...
I was wondering would that fit 30's or 235/85R15 without a lot of rubbing? My brother works at an auto wreckers so that stuff is everywhere :P but what i am most confused about is if i crank the Torsion bars 1.5" what size shackles would i have to put in the back? people say that rear shackles only lift half the size of the shackle... so would that mean id need a 3" shackle? |
If you wanted to lift the back 2", you need a shackle that is 4" longer that the stock one.
Or you could do add a leafs, may be easier
That's the lift I'm running, and I fit 31's easily and 32's with a lot of extra work and modifications. With that lift you should be able to fit 30's no problem.
(Post 625416)
This is all speculation and research beforehand as i am finally getting back to putting an engine in to 'er :P |
