-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   1999 blazer 1.5-2inch lift (https://blazerforum.com/forum/lifting-tech-44/1999-blazer-1-5-2inch-lift-14296/)
Dhurteau 11-08-2007 02:59 PM
I would rather 2inch, call me a dunce i have read 3 pages here and still dont feel comfterable with lifting it without asking this for my particular situation.
What is the cheapest way to acheave a 1.5 inch lift. I can do the work my self, i just need to know what parts. Id also like to try ato aviod the tbar because i read about peoples ball joints going to hell, and the boots pissing grease. Or is that wrong?
Any ideas?
RCars2 11-08-2007 03:16 PM
RE: 1999 blazer 1.5-2inch lift
Yep, if you crank the t-bars it can do fun things to your front end. Thats not to say you cant keep on top of it but i can attest to the fact that it will cause more wear. As for 2 inches of lift on the cheap, get a body lift. Its safe, fairly cheap, rides like stock,and you can install it in an afternoon if you have all the tools handy (good set of sockets and a sawsall, grinder, or plasma torch to modify the back side of the rear bumper)
cyukio 11-08-2007 04:27 PM
i think you could also usecoil spacers and shackles. you dont have to modify anything and i think its a lot faster, the body lift is a good idea too but then youll have to put on bumper brackets, front and back and if its your first time doing something like this its hell and takes longer than you would wish. trust me ive been through it.
Dhurteau 11-08-2007 04:37 PM
Could you point me to a GOOD quality body lift
and a good quality set of coil spacers and shackles? Price expected to pay etc?
Call me a dunce but how do you install a body lift? Where do all the black bits go. Be easy on me. Im new to lifting etc.
thegr81 11-08-2007 04:41 PM
Look at the 4th post down which is me with a link to a great website for what you need
https://blazerforum.com/m_105453/mpa.../tm.htm#106791
search and you shall find, this will take you to 2wd set ups but searching within the site is easy and you can find the 4wd stuff quick.
Dhurteau 11-08-2007 04:50 PM
found this, http://www.rockymountainsusp.com/W_p..._body_lift.htm
Still not sure how the body lift works. If someone could explain please.
thegr81 11-08-2007 04:53 PM
To put it simply, a body lift seperates the body from the frame, by lifting it. Now on that site the body lifts come with everything you need, from bumper brackets to steering extensions.
Dhurteau 11-08-2007 04:57 PM
how difficult is it to seperate body from frame? Will i have to worry about the liftbits (little black things)falling apart?
thegr81 11-08-2007 05:22 PM
The body lift kit comes with everything you need to do the body lift and it replaces or adds to what is allready there.
Dhurteau 11-08-2007 05:42 PM
Im just trying to get a general idea here, where to jack the body etc.
So, if i was to "jack it" now and look. I would see simmilar black round bits all around the frame?
