-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   1999 Chevy Blazer; Torsion Bar (https://blazerforum.com/forum/lifting-tech-44/1999-chevy-blazer%3B-torsion-bar-94806/)
Chevy3blazer 06-12-2017 02:32 PM
Hi, I've been reading around about how I could raise my blazer up a little bit by adjusting the torsion bar. I want to lift it up. I was excited to try it out but when I went to go look for it. I couldn't find it anywhere under my blazer at all..Why doesn't my blazer have one and years before 99 and after 99 have torsion bars?? NEED HELP!!!
Rusty Nuts 06-12-2017 03:50 PM
Welcome to the forum. Is yours 4 wheel drive? They use a torsion bar instead of a coil spring.
Chevy3blazer 06-12-2017 05:26 PM
[ I have a 2wd blazer. I can't find the bar on my blazer
QUOTE=Rusty Nuts;677419]Welcome to the forum. Is yours 4 wheel drive? They use a torsion bar instead of a coil spring.[/QUOTE]
Rusty Nuts 06-12-2017 05:53 PM
There is no torsion bar to find.
Chevy3blazer 06-12-2017 06:05 PM
How?? Other blazers have it. I was trying to find the torsion bar to give my blazer a lift. If there is no bar on my blazer then how do I lift it?
rriddle3 06-13-2017 06:24 AM
Torsion bars are only on 4WD Blazers. You have a 2WD, so there are no torsion bars. You have coil springs on the front suspension instead.
Chevy3blazer 06-13-2017 11:13 AM
Ohhhh that explains it, soo is there an alternative way to lift my blazer then?
rriddle3 06-14-2017 06:45 AM
*Moved thread to'Lifting Tech' section.*
blazen_red_4x4 06-14-2017 07:34 AM
Coil spring spacers, taller coil springs, lift spindles, floor jack... Although I've never personally seen one for a 2wd, a full bracket lift that drops the control arms down may be available, at a price. Nothing as cheap and simple as adjusting the torsion bars on a 4x4 unfortunately though.
