2" Rough Country Installed
From the one photo it looks like you have the same issue i had with the lift, negative camber. Once you do the wheel alignment should fix that. I aggree I would like to see your cv angles as well.
Thanks alot. I will be sure to take some pics of the cv angles as soon as I can. I already had an alignment done and everything checked out ok. I didnt get as much lift out of the back as I thought I would so I think im going to get AAL. Do youwhere I can get like 1" or 1.5" AAL.
To Motoraser125:
Have a blazer similar to yours besides mine is only 2 door. Have the same grille guard and lights howerver. Was thinking about getting the Rough Country Suspension Lift for mine. Just wondering if there were any problems you encountered and how your blazer rides after putting that lift on? Thanks
Have a blazer similar to yours besides mine is 2 door. Considering putting the Rough Country 2" lift on my blazer. Did you encounter any problems while putting it on? Also, how does it drive with that lift on. Kinda new to this whole thing so any suggestions would be appreciated. Thanks
