| El_Beautor |
09-15-2017 10:18 AM |
You could probably run 31's on factory rims depending on the tread, but you may rub a bit, especially with the suspension compressed. The most likely spots you would touch would be the back of the front fender-well, and possibly the frame at full lock if the tire has a heavy shoulder lug. A bit of trimming of the back of the fender will take care of that spot, and the frame rub (if you do) is very minor. Definitely not enough to bind. Mine did it for a bit when I ran 32's but it was only enough to shine the rust off a 1" triangle.
