2 inch Body lift
Hey guys,
I'm new here and I've been searching through a few threads but I couldn't find what I was looking for. I was looking into the "Body Lift Kit - 132" from PA for my 96 S10 4x4 4dr. I was wondering if anyone had any personal experience with that kit. I just want to know if they've heard anything (positive or negative) or if you have any other recommendations for a 2 inch body lift. I have 31x10.50R15 Firestone A/T on there now and I just need a little more clearance. If any of you guys have installed one of these before, is there anything I should know before digging in? Thanks in advance... |
Originally Posted by mikeic4
(Post 533456)
Hey guys,
Yeah, I had to trim a little before getting the 31s on there. I'll order the lift and put it together real soon. Hopefully finished up by next weekend. Thanks for the reply.
BTW- I love the look of the camaro wheels. Thought about those after doing the lift. |
been there and done that, i would reccomend an air impact tools,and dont forget the bolts over the axle, there kinda hidden,also use plenty of
PB blaster to loosen the rusty bolts before starting, i also replaced the body rubber mounts with the urathane type,the origionals were starting to crack and break,take your time and DONT take all the body bolts out at one time.... and just go for it,will help to have a friend lending a hand.. pics gotta have pics |
Thanks for the heads up man, I ordered my lift today. Should be here in a few days. Before and after pics will be up soon! (Hopefully) lol
Started the lift today, got just about half way through. (started late after work). Hopefully if I have time tomorrow it will be all finished. If it wasn't for okiedoak I never woulda saw those bushings hidden in the back. Pics will be up tomorrow!
(Post 535205)
So yeah, due to rain, puddles, work meetings and lastly, lack of time... I was finally able to finish the lift TODAY! Only thing that didn't go exactly as planned is the steering. I noticed it after I started to move the truck around and test everything. After about a quarter turn left, there is like a binding? tightness (absolutely no issue turning the other direction). I can continue to turn after that inital tightness without a problem. Has anyone ever had or heard of any issue like that? I reread the directions over and over to see if I missed anything and I couldn't find/think of anything. Any insight on what is going on or if it is not good to drive would be greatly appreciated. Sorry for the wall of text, I just want my truck back. |
Cv or breaks binding?
after i lifted mine, there was a very solid "click" in the steering, i think it was in the steering shaft where it telescopes together, i kept driving it and its not there anymore,go figure... if you examine what is taking place on the body lift,all components are remaining in the same location except for the steering shaft, I know the brake lines move and the fan shroud moves, but nothing in the steering or suspension moves,except for the steering shaft, that is why i felt that it would be safe to drive and see if the "click" would go away and it did..also congradulations on the lift,it is a pain but not hard
to do.... and where are the pics???? |
remove your airbox and get someone to turn the wheel and check out your steering shaft when it starts to feel like its binding, maybe mudflaps if you have them mine rubbed on them don't know if that might be causing an issue.
| All times are GMT -5. The time now is 05:01 PM. |
